Abs headaches | Ford Explorer Forums
Abs headaches
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
Am getting DTC indicating ABS Module Failure. That's throwing it into limp mode often, and is making driving a chore.
Any info on replacing the module would be appreciated. Neither O'reilly nor Auto-Zone lists replacement ABS modules.
Thanks! imp
Had an ABS light when i first got the 04 and looked around for a module before finding a split cable.
they were hard to find and about $80-150 online. my last ditch before the junkyard was to check to see if the cruise control cutoff switch went bad, sometimes they say if affects the module.
then i saw peanut shells in the manifold and found a chewed brake line and ABS line... hungry fella.
