Mattbuyshouses
- June 5, 2003
- Rockford, IL
- '95 XLT
I've had a problem with my anti-lock kicking on at some of the strangest times recently. Mostly it happens when I'm going very slow and turning like pulling into a parking space. I'm in dry, stable conditions which is why this is concerning me. I'll be pulling into a parking space as I mentioned, and the abs will start pumping the brakes. I keep the brake pedal held and just as it should, it stops pumping and I still have control but I'm concerned that there may be something very wrong. It may not be in the abs themselves but has anyone else had a similar problem or concern?
Any advice would be greatly appreciated.
Just as an fyi, the brakes seem to function very well in all conditions including hard braking in all weather conditions. The pedal is NOT mushy at all. I had the brake pad/shoes and rear rotors replaced just this summer and they didn't need anything else. It is just a concern that the abs is coming on in slow braking conditions.
It IS possible that I need new balljoints... not sure if this is a part of the problem or not.
