Ac clutch cycling with heater on | Ford Explorer Forums
john cris
Lakeport, California
2003 ford explorer XLT
When the heater is running the AC clutch cycles which I think is normal. But I noticed that the idle rpm also drops when the clutch engages. It’s more of a bounce, as it trips on the rpm will drop momentarily. The clutch cycles every few seconds. I haven’t seen that occur before. Something doesn’t seem right. Suggestions?
why does the AC clutch cycle when using the heater? Are vehicles with no AC that much different? I haven’t used the AC in a long time. The system functions and was recharged a couple years ago. Maybe I can just eliminate the AC?
It cycling is to remove moisture from inside the truck
The cycling is normal
But if it's happening every 10-20 sec then most likely low on Freon
Noticed this morning that it cycles the clutch only when the defrost is on. The rpm drop wasn’t as much as yesterday. I’ll check the Freon charge.
I wouldn't delete ac. It makes a measurable difference in defrost/demisting windows.
It's normal for the AC to engage in both defrost and floor/defrost, at least with temp above mid 40's or so.
Just checked system pressure:
Low cycles 20-40
High 50-75
Checked system
Low cycles between 20-40
High cycles between 50-75
Ambient 45-50 degrees
That's very low. But my ambient temp was probably 80 degrees when I checked it back on August 9th.
I can't even find a chart that goes down to 50 deg ambient.
I couldn’t find a chart that went that low either. I’m going to run a can of dye through see if I can find a leak
