AC Compressor cutting on and off randomly, Replaced Sensors, Switch, and Vacuum Recharged System | Ford Explorer Forums
Currituck
2010 Ford Explorer
I can't quite figure out what's going on. Sometimes the compressor stays running even when the switch is off, and sometimes it cuts off when it's supposed to be running. This all seems to be random. I've replaced all the pressure sensors, selector switch, and also vacuumed down the system and refilled it. While refilling the system, we had an issue where it didn't appear to be calling for the compressor after checking for voltage at the compressor terminal. Is there another switch or sensor that could be causing this, or should I just assume the compressor is bad now?
This is on a 2010 Ford Explorer 4.0
