add ons | Ford Explorer Forums
add ons
pat3
vancouver washington now i reside in hawaii
91 xlt 4 door 13inch lift
i just bought a couple items and was wondering if any one was running them and some feed back on them i havent recived them yet
pace setter headers
bbk throttle body
accel coil
thanks for ur time
I run all three and like them.the pacesetters have two places to mount o2 sensors and if you still have a 91 motor you only have one o2.oil pan drain plugs fit the o2 holes but you will need mount a single one near the collector in front of the cat for it to read right.the bolt size is 22mm 1.5 and made by dorman #019495090557
ok and i already did a o2 after the y.
did any real performance feels just pop out to u after putting them on
I did a bunch of work at once so couldn't tell you.I did notice a big gain after changing valves and port match and p+p the upper and lower intake.if your doing a turbo do you plan on doing anything to the motor? I would aleast gasket match and port and polish the upper and lower intake manifold,a lot can be taken out and you don't have to tear the motor down.
no not at this point in time. i found water in my exhast so i dont wana go any further till i get to the botum of it
