ADVICE ON LIFT | Ford Explorer Forums
ADVICE ON LIFT
Biteme2718
San Antonio, Texas
Explorer 97" XLT
I wanna run 32's under my 97. Will a torsion twist and warrior shackles be enough lift to do this and if not what should I do.
It will rub a little and you will have to trim a little. If you add a 2inch body lift you shoud be fine.
Who has a 2 in body lift for the explorer?
you would have to fabricate a PA ranger BL i think it's the 853? anyways i'm running 32x11.5 w/only TT and shackles-had to do a moderate amount of trimming and they rub every now and then-if you're going to run 32's i would also suggest a 2-3" body lift.
NO LIFT IS NEEDED!
I got 32x11.5 and they do rub a tad on the front swaybar and that's it. I also fad to trim a tinny piece outa the tupperware.
need to do to fit: TT/Shackles/AAL and longer shocks will help
Hey did you put your shackles on yourself? And if so how hard is it to do?
Shackles are very easy to do....just two bolts on each side. Unbolt the old and bolt in the new. One end goes to the frame the other to the leaf pack.
