Aftermarket options for ‘00 Ranger fuel hanger assembly? | Ford Explorer Forums
Las Vegas, NV
2000 ranger 3.0l flex
Things got a little crazy with this 5.0 ranger swap...thinking I’m going to need an aftermarket fuel hanger or at least hangar “hat” or whatever it’s called. I’ve seen options for various mustang years that have 8an/6an fittings native, but had never seen if any are compatible with the explorer/ranger setup, harness or sending unit. I’d like to retain the sending unit so the stock gauge works. Open to options of an external fuel pump controller as well, not sure if the stock is sufficient to supporting up to 800hp. Going to 450lph pump, 8an lines from pump to regulator to rails.
Any suggestions?
