Air conditioning stops cooling even on mild acceleration... | Ford Explorer Forums
bitkahuna
FL
'06 Limited
I've heard of cars turning off the a/c compressor on hard acceleration but my V8 Limited seems to do it even on very mild acceleration which is very annoying in the heat wave we've had lately, as I can feel warmer not dehumidified air coming in.
2 things I can think of that can cause this
1) the R134 is low which when revving the motor is causing a low pressure condition which turns off the compressor clutch.
2) the orifice is clogged which when the compressor spins faster is causing an extreme high pressure situation which will also turn off your compressor clutch.
There are pressure sensors on the high and low side of the compressor these will turn off the compressor when there is too much or too little pressure. This is a safety feature to save your compressor from burning up, and/or your lines from blowing.
Another, less dramatic, possibility is that you have a vacuum leak or your vacuum reservoir is full of condensate. The vacuum reservoir holds the vacuum to keep the vacuum operated vent switches from changing position when the car is under acceleration.
Does the pitch of the blower motor change or the volume of air coming through the vents?
FWIW there's no high pressure cut out switches on the orifice systems, a high pressure relief valve yes.
Does it cool well when not being rev'd ?
What is the air temp coming out of the vents?
Don't have a thermometer to measure air temp from guages, but the air is nice and cold when driving steady or stopped.
