Airbag code 34 | Ford Explorer Forums
Airbag code 34
natedoggaz
2002 Explorer
OK - I had a code 34 for quite a while and I believe I finally fixed it last night.
Had to fix my battery terminals so it was disconnected for quite a while - thought it would be a good idea to figure out the problem.
I had found on ths forum that code 34 was a disconnect with the passenger seat. It was a pain in the a$$ to look under it and find out which connection was the culprit. I pushed together a couple connections under the seat - not knowing which was the one casuing the problem. I hooked the battery back up and went for a test drive and the light did not come on!
Does anyone have a picture of the connection that caused this issue - since I am nort sure which one it is? I will be able to go straight to that connection if it happens again...
Thanks!
ND
I am not 100% certain. But most Air Bag connectors are yellow.
AH - OK.
I do recall seeing a yellow connector under the passenger as well as the driver seat.
Thank you!
ND
