Alignment | Ford Explorer Forums
Alignment
fireftr
strongsville,ohio
'05 Limited 4.6
Help! Just got new tires and an alignment on my '92 EB w/185k. Had to have the Good Year place reset it three times as it keeps pulling to the right. The tech said it was set to specs the first time, so he tweaked it after a road test and rotating the tires. He even agreed with me that it was pulling. I took it back a second and third time, but it still remains. He gave up on it, but I'm concerned that my new tires will get uneven wear. Nothing on the right side is dragging and it has all new front end parts.
check the rear suspention something may be loose but i would take it to an another alignment shop cause sometimes the calibration can be off with the alignment equiptment. this has happned to me twice
how in spec? often times with the first gen, cater/camber change in correlation with each other... one might always be out even if the otehr is perfect....
