asp84
- July 2, 2001
- Tempe, Arizona
- 1998 V8 AWD Mounty
Just curious,
Its a fact that you hook up the White/Purple to a "crank" only source.........along with the Red and Light blue. Although if you check the diagrams for the 60 pin connector (EEC-IV Module Connector Pin Usage chart) , there is no indication of a White/Purple wire that goes in to the EEC-IV computer. Also under the definitions for the 60 pin connections for the computer there is no such input for a " crank only" source.
Anyway, My Question is, Where does this White and Purple wire go to???? WHat does it connect to. (So far, I have only heard the theory of, "it tells the computer that you are cranking, and gives it a different set of commands for starting) This sounds great, but there is no crank only wire that goes to the computer.
Anyway, can somebody with a Helms manual trace where this wire goes? Personally,
