Almost a Heater | Ford Explorer Forums
Almost a Heater
gregtarris
Allendale, NJ
94, 98 sport, 02 xlt
My heater is not putting out the heat. The blower is good, but after driving for over one hour the heat being generated is very warm not hot. This is in weather that was in the thirties! Any ideas?
My friend had a problem that is similar to that I believe, also with a '98 Sport. If it is infact the same problem, he was waiting on a part to fix it. I'll ask him what he did.
What does the coolant temperature gauge read?
Sounds like the blend door
My 97 had that problem two years ago. I cut a hole in the plenum and moved it by hand. Nothing to loose, you get a new plenum if you fix it later (not a cheap repair). I've been happy enough to do othing more. Search for Blend Door, so you're cold, cheap and lazy.
