Alternator question? Kinda long | Ford Explorer Forums
Vacaville, Ca.
1997 limited (gone)
Hi Folks;
Well; I got 5 years out of the old motorcraft battery in my 97. Not bad. Unfortunatelly, it died at work. I had to have a co-worker come from another site to give me a jumpstart. And; I still had 7 hours of my shift to go! I had to charge the battery with the alternator. That took a while!
Contemplate this picture:There I was, all alone, sitting there in the middle of one of the projects in San Francisco, (this place takes up ten city blocks) I'm sitting right smack-dab in the middle of it with a dead battery! Damn; there is only one other white guy here; and he's a tenant! Oh; wait a minute! I'm the one in a uniform! Lots of these folks here don't like me. (funny how people seem to hate your guts when you arrest them!) Man; talk about sphincter pucker. Good thing we carry guns! (yes, legally)
I went straight to Sears the next morning and had them install the best battery they had on hand for my truck. I also had the guy test the output of the alternator right in front of me.
According to his test equipment, my alternator puts out 1-2.5 amps at idle; and 70-75 at 1500-1700 r.p.m. Is this normal? The guy at Sears said "yea, that's about right". I can understand the amp figure at higher r.p.m's, but what about at idle? I spend a lot of time idleing. I use my truck for my job, and on cold nights, I spend a good part of the shift idleing.
I need more amps than that at idle. I will be running my laptop, a printer, cellphone car kit, and a radio while sitting at work. I am sure these items will require more amperage than 1-2.5 amps.
Question 1: Is this normal for what I assume to be a 90 amp alternator? Or should it be doing better than this?
Question 2: Would the 130 amp alternator put out more amps at idle?
I am already pretty sure I will be getting the 130 amp alternator soon. I just need to know if it will keep up with my accesories at idle.
Question 3: Is the battery guage in my 97 similar to the oil pressure guage? By that, I mean; is it just a glorified idiot light with a needle on it? When the battery was dead, and while i was running it at 1500-2000 r.p.m's to charge it that night, it hardly moved at all. Is this normal for these?
Thanks;
George
One thing you can do is use a smaller pulley on the alternator. We did this by accident (one of the replacement alternators I bought had it). Now at idle I can turn up the stereo and the lights dont' dim near as much as the used to.
Best thing to do is measure the size of your pulley (number of groves and diameter), then go to a yard and start measureing pulleys. I'm sure you can find one.
I never measured how many amps our alternator puts out at idle.. but our 90Amp puts out 80ish at 2000 rpms when hot.
~Mark
