Ru Dawg
- July 26, 2000
- Wyomissing, PA
- '95 XLT
OK, I'm pretty much settled on a Q-logic bandpass box and 2 12" Infinity Perfects.
First questions is if I wire the subs in parallel to create a 2 ohm load, then the total RMS power I can feed them will be the sum of each sub (350+350) which is 700watts RMS....correct?
Second, the closest amp I can find to get 700 watts @ 2 ohms is an Audiobahn which puts out 600 @ 2ohms...is this enough or will it under power this setup.
Third, if a 2 channel amp is rated at 350watts bridged @ 4 ohms...would that make it 700watts bridged @ 2 ohms?
Am I making any sense???????????? LOL!!!
Also...what about the Perfects...any better suggestions?
