I have a 91 EB and I took out the stock amp that was above the wheel well on the right side behind the plastic and replaced with my soundstream amp. The fit was pretty tight but it did work and you can't see it at all if you take the time to do it right. The only down fall was that it is kinda hard to ajust once you get it in. I also put two other amps under the back seat but instead of mounting it to the floor I mounted them to the seat brackets. The reason for wich was to allow the seats to fold down without hitting the amps.
You can install them behind the rear seats in the back cargo area. Do not attach them to the seats, but rather to the piece behind the seat that fold down. If you put it in right, you can fit one amp on each of the two pieces. As I have it in my truck, the amps cannot be seen at all with the cargo cover on.
