BuffaloXplorer
The X had to go!
- April 5, 2004
- Buffalo, New York
- 2006 Impala SS
I sincerely HATE to do this
, but after an hour or so of searching i believe my problem is a bit different than the others' i've read.
When i start the X in the AM (it's generally cold), and sporadically throughout the day (regardless of engine/ambient temp) it revs around 1200 rpm (it sounds higher, though). It takes quite a while for it to come back down to the 7-800 or so it normally is, and generally not within the 10-15 minutes i let it warm up in the AM. If i drive it before it settles down, i can actually feel it trying to push through my braking when i'm stopped at a red light & such. Eventually, it will go away, but well after the engine is at proper operating temp, so that has nothing to do with it (?). While it's revving high, it does not surge - it's steady at 1200.
At first i thought it was a sticky throttle body, but i've popped the hood when it's revving high and determined that it is fully closed. I also disco'ed the IAC and it stalled right out. Does the TPS have any effect on how fast the engine runs? I haven't yet taken to testing the components electrically, though, which would be my next step. I know the TPS ideally should be at .96v at idle - what about the IAC?
Ideas? Thanks in advance.
