BrianDye
I'll have another...
- March 1, 2009
- Monroe, MI
- 2006 XLT
I have read numerous threads relating to changing the plugs out, but I have a few questions still, since alot of them seemed to go back and fourth.
I have a 2006 with the 4.0 V6.
About the only steady info I could get is the gap should be set between 52 and 56, so 54 to be on the safe side. Also, that the plugs are relatively easy to change, just go through the wheel well for the back passenger plug.
I keep seeing stuff about these plugs and waste something or other, and that we need special plugs.
I would normally go with Motorcraft plugs, but it seems as if some members reported a loss of power/MPGs or a rough idle with them, and ended up with some NGK plugs. I would like the best performance I can get, I don't mind spending a few extra bucks on such a crucial part, but if there's no difference, I would also rather save a few bucks per plug.
I am changing mine for a few reasons
1. Just normal maintenance at 80k miles
2. I have a bit of a rough idle, and I can hear it in the exhaust
3. I have a very slight shudder sometimes when I lightly accelerate like bumping the cruise up a mile or two per hour. Thought that was trans related, but read a post where a member described the exact same issue, and was fixed by replacing his plugs/wires.
I also have not really worked on an engine in quite some time, last engines being my old 90's Explorers. Am I JUST changing out plugs and wires here, or are there other things that should be done as well related to plugs? I thought someone said something about coils? Sorry if this is a dumb question, but what is that?
I would prefer to order the plugs and wires online, as it seems to be about the same price for premium parts online, as basic non-OEM quality parts are in part stores.
Thanks in advance!
Thanks in advance!
