dlr281
- October 23, 2007
- Decatur, IL
- 97 Mountaineer V8 AWD
I have a 97 mounty with the JBL and 6 disc changer. It has what I believe is a 6-6.5" sub which is blown. I want to cut the hole bigger and put an 8" sub and use the stock amp. Is the stock amp 4 ohm or 8 ohm? Will a Kicker Comp C8 work? It says the top mount depth is 4-1/8" and cutout diameter is 7-1/6"
