SteveKieran
- December 2, 2015
- Portland, OR
- 2001 Ford Explorer EdBaur
I'm stumped. My blower fan worked intermittently, so I replaced it and the fan resistor in my 2001 Explorer. Now when the fan is on, I have no air pressure at any of the interior vents. No defrost, panel or floor. All worked fine before the fan/resistor changeout.
Good news is that there's faint heat when heat is on, and faint cooling when A/C is on. So temp controls seem to work fine. Also, the recirculation door behind glovebox opens & closes fine. And I can see (or feel) 2 other actuators behind dash opening and closing with no loose arms or parts, and no clicking or sucking noises.
So my thoughts have been: 1) look for failed vacuum lines near area of fan--hey, I could have pinched one! But found nothing. 2) Pulled out fan & examined--it spins CCW at all 3 speeds. 3) Listened for hissing lines or Click Click under dash--nothing. 4) Logic says that if any of the vacuum actuators have failed, its related door will be open for either cooling or heating, even if it's to the wrong vent...and that's better than what I have now (no blowing air at any vent).
Your theories are appreciated!
