Thanks for the info, you and your technical abilities are really appreciated!!
the "PCS controller" is that the one used on the 5r55w transplant?
My goal is towing performance and transmission longevity, without really spending a lot of time I'm not sure how I would pinpoint where the shifts would be best. Aren't the shifts also affected by the TPS? To get a program that would work good in all towing situations might be difficult, but you would know that better than myself. That is why I guess I gravitate to the "paddle" style manual shift it would be the best all around solution of control.
I just don't like smashing the throttle to downshift, that seems like it would be the worst thing to do on a hill with a heavy load. As apposed to a nice smooth light throttle downshift and then apply more throttle as needed.
The shift kit REALLY helped the snappiness of the up shifts and downshifts, but it didn't change the timing of the shift. How much control can you program into this thing?
Maybe I should fill you in on what I've done so far, and where I want to go with this truck (as time and money permits)
My Truck:
2001 Mounty 4.0 SOHC 4x4 4.10gears(OEM)
Mods to date:
Transgo shift kit
New EPC
Full Synth ATF
Tranny Drain Plug
2 Plate style external coolers
External tranny filter
Tranny Pressure & Temp gauges
TT Twist, Shackle, AAL (1" rake)
Air Shocks for smoother towing
New struts
Engine Replacement (long story)
Mods I need to do:
Additional Lift (probably 3" body)
Larger BFG A/T's(not sure of size dont want too big)
Exhaust (Still researching this one, something good for towing torque)
Check/Test all the sensors (TPS, MASS etc..)
K&N Air Filter/ or Intake (still researching best ( read:cost effective) option)
Weld/make Skid plates/brush guards
Better lighting on the front
I think that about covers it, what say you oh wise one of dinosaur cumbustion enhancement
