yob_yeknom
Moderator Emeritus
- November 14, 2000
- Glade Hill, Virginia
- '97 XLT & '06 Limited
Okay, so has anyone with a '97 and the SOHC engine change gear ratios? Anyone else know what to do about fixing the speedo and all that? I have no idea if this is all the same for any other year. Here's why I ask... (all this is coming from my factory repair manual)
The 5R55E tranny (comes on models with the SOHC) on the '97 model year still uses the gear driven speed sensor on the tranny itself to send the signal to the speedometer.
Vehicle Speed Sensor (VSS)
l The vehicle speed sensor (VSS) is a magnetic pickup that sends the powertrain control module (PCM) vehicle speed information.
l The VSS sensor is mounted externally on the left-side of the transmission extension housing.
l The PCM uses VSS information to help determine electronic pressure control (EPC), shift scheduling and torque converter clutch (TCC) operation.
I'm switching from 3.55 gears to 4.10 gears and 33" tires, which will give me a close to stock final ratio. The sensor sees a faster reading due to the gear change making the driveshaft turn faster, but the tires are larger so that equals it out, so I think the speedo will be fine and that won't need anything done.
But what about this...? The Programable Speedometer/Odometer Module
Programmable Speedometer/Odometer Module (PSOM)
l The programmable speedometer/odometer module (PSOM) receives input from the rear brake anti-lock sensor. After processing the signal, the PSOM relays it to the powertrain control module (PCM) and the speed control module.
l The PSOM relays speed information to the PCM and the speed control module in miles per hour (mph).
l Information from the PSOM is used by the PCM to help determine shift scheduling, torque converter clutch operation and electronic pressure control (EPC).
How does the change affect this? The rear ABS sensor is on the axle spline, right? So it won't see a faster reading due to the gear change, but will see a slow reading since the tires are larger. Am I right about that?
So if I have 2 sensors telling the tranny when to shift gears, and one sensor reads way off the other, what's gonna happen? Or am I wrong about the whole thing?
Sorry, I'm confused...
