asp84 need your help!! | Ford Explorer Forums
mach1460
laramie Wyoming
93' limited
asp84,
im going to message you this too but incase someone else knows, what did you use for a fuel pump on the 5.0 swap in your x?? also what oil pan and one more thing did you use the factory 5.0 air cond.? what did you need to get that hooked up??? thanks!
Al rarely frequents the forum anymore. Too many chicks in his new neighborhood to get to know.
I'd try IMing him at MrASP84
Here is a link to his A/C info http://home.earthlink.net/~asp84/ac.html
I'm pretty sure he used the FP from a 302 Explorer.
did he upgrade to a 5.0 tank??? or did the pump fit into the 4.0's tank? o and is MrASP84 is that a aol im screen name?
Yeah.. I'm pretty sure the Explorer uses the same tank on all engine options, just different pumps.
MrASP84 is his AOL IM Screename. I should have been more clear there. :eek:
