RedEB
- February 21, 2004
- Portland, OR
- 97 XLT
After having taken a week to replace lower and upper intake manifold O-rings, thermostat housing (w/ thermostat and sensor + sender), primary tensioner, spark plugs, ignition coil, wires, and rear tensioner- my previously running-fine X has taken the dump on me. I have replaced the coil, wires, and spark plugs and even tried brand-spanking new parts to determine if these were the culprits.
Here is the background: 97 SOHC w/ 153K miles. Engine was running well before the operation, chain rattle was evident but not pervasive. Apparent vacuum leak that was audible though no CEL was present. Engine ran a tad rough cold but would smooth out beautifully.
Here is what is currently happening: random misfire on #4 and #5 (according to dealership, no CEL or other computer codes are present). They also stated that #4 and #5 have 6-10% less compression than the other cylinders (insignificant in my book....). Again, No CEL or code is being thrown. It should be noted that I screwed up the firing order when installing new coil and also failed to insert the ground on the coil, so I had many hard starts before finally figuring out the sequence for the screamin' demon pack ( was original, not the sequence mentioned on this website).
I am truly at a loss. Of course, the dealership is screaming, "buy a new engine!!!" But I don't think the engine is dead. It doesn't sound good at idle, but I am still able to get up to 70mph without much effort. It stumbles and misses when confronted with a hill or sudden acceleration. Any ideas?
PCV? intake O-rings (maybe I screwed them up)??? COuld the new rear tensioner have opened a can of worms? This vehicle is our only vehicle- any help would be great!!!
