Bapster
- November 21, 2012
- 1999 Ford Explorer XLT
Hi all,
recently I was having problems with my 4hi and 4low not working, came to you guys and you told me most likely the transfer case shift motor, so I bought a new shift motor, and boom my 4hi and 4 low now work, (Big thank you to "Flash", "4.0blue98", and "mr_valingo" for their help
) or seems to I think, but when I put the new motor in, I wasn't thinking and didn't see a video before about popping out the little bullet ends out of the rectangular black harness, so I ended up cutting those wires from the 2 hall effect sensors. So I reconnected those wires, twisting them together tightly, soldering them and then covering them in heat shrink tube, at first the auto 4wd would kick in and the entire truck would vibrate (I was gunning it to make sure it still worked), now the auto 4wd doesn't seem to kick in at all, but the 4hi and 4low still seem to work from what I can tell. Anyways, if I can find those 2 hall sensors somewhere, would that fix it?...Any help is greatly appreciated guys, thank you
