juicemanfta
- December 6, 2006
- 2003 V8 Limited.
So I want to do my first AT oil change, but after reading the posts in here I decided to give ford a call to see how much they would charge to do it.
Ford wants $200 CAN + $60 for Mobil 1. They said there is no filter so the strainer would be cleaned out with the system they have.
They also said they would use a cleaner to flush the AT, isn’t this bad? I read somewhere that using this can clog up the ‘strainer’ and eventually choke the AT from oil flow.
Should I ask them not to use this? should I use the original oil instead of the Mobil 1? The reason why I asked this is because I read it is not good to mix oil (some of the old oil ma remain in the AT after the change)
