Aux tranny cooler? | Ford Explorer Forums
Aux tranny cooler?
Malcolm
Armonk, NY (westchester)
'92 Eddie Bauer
I have a 92 Ex and am just wondering if I have a tranny cooler already? I am getting my transmission fixed and figure that it is a good time to get an aux tranny cooler (if I dont have one already). Any Advice? Does anyone who has a 91-94 have an aux cooler? Where should I get it from and what size?
Thanks alot.
Well I have a '92 and I think that I do have a cooler in the front of the radiator on the drivers side. Is it reccomended to get a new cooler, say one from summitracing? Is it a good idea to replace the stock one on the Ex?
Thanks.
So what you are saying is that there is no real need for the aux cooler because the stock one works well enough?
I think unless you work your Ex hard, you'll be okay with the stock unit. Like Gimp said, unless you need the extra cooling capacity. If you're running a substantially larger tire (probably 32" or larger, not sure how big starts working the engine too hard) or if you have a performance bent, you may want the auxilary cooler.
Thanks
That makes a lot of sense...thanks a lot guys.
