Auxillary power plugs | Ford Explorer Forums
Ford XL plus
2015 Ford Ranger XL plus
Good day,
Please assist me. I notice the two 12 volt auxiliary power points on my dash does not work. I drive a Ford Ranger XL Plus Double Cab. If it is simply a fuse, can you please indicate specifically which fuse and in which fuse box I must look at.
Thank you in Advance
Bennie
Have you looked at your owners manual? It should have info on which fuses are where.
Hi,
I think the XL plus is different from the generic manual, as there is an auxiliary battery pre installed
Seems like it would be worth looking at, or did you already? I would think the manual the factory gives you would cover the model you bought, no?
Your best bet is to check the owners manual. This forum is primarily American, but the global ranger isn't sold here. So nobody on this forum has a XL plus.
