axle flip | Ford Explorer Forums
axle flip
gt fast
92 xl
i got a 92 explorer ex. now, its 2 wheel drive and i work in a very muddy,bumpy,hilly area. i was running 235/75r15's until i decided to by some 31x10.50 15's and they help alot at work. i was wondering if anyone knew how much it would lift my rear end if i did the axle flip. and if anyone knows a good lift thats fairly cheap or a cheap way to lift it. i want to be able to run 33's, or just get a small 3-5 inches out of lift and still run my 31's.
axle flip will give you 5.5
f150 coil seats and shackles will give you around 2",cheapest way to go
There Is a Skyjacker 2" Lift Kit For The Front That Is Worth The Money , Got Mine Used Pretty Cheap
so hold on. your saying that if i move my axle to the bottom as opposed to its location right now where it lays on the leafes, it would give me 5.5 inches of lift back there?. and on top of that i can use f150 shackles. then use f150 coils and spacers up front? what year f150
Soa gives you 5.5 inches. The cheap way to get 2 inches is to get f150 coil bucket seat and some shackles for the rear.search
