Definitely moving. Inspect the mounts. They had to separate the engine and transmission to get to the main seal. I question if they tighten the bolts/nuts of the mounts. Check the transmission mounts also. If they removed the engine to replace the main seal I'd check the engine mounts. If they dropped transmission to access the rear seal I'd check transmission mounts. Let us knownwhat happens.
