CBenson
- April 25, 2010
- Davie, Florida
- '96 XLT
I have a 96 XLT with the 4.0 OHV. I am getting a intermittent rough idle but only for a few moments (about 10-15 seconds) at start up. When I am giving it gas it continues to run rough similar to a dead miss. I am not having any codes but I did some data streaming and the fuel trim is running at 24% and the MAF is reading at 4.9 g/s (not sure what g/s means). I unfortunately forgot to look at my temperature sensor readings. The O2 sensors are fluctuating so they seem to be operating properly. I will read the temperature sensors when I get to work tomorrow and post the results. I am not sure if this is an issue or not but I have only been getting 14 MPG for the past month. I only know this because I recently changed the gear in the odometer (it has been broken since I got it 3 years ago). Is this an average mpg?
I changed the fuel pump about 2.5 years ago but have not checked fuel pressure. I changed the fuel filter last year but have probably only put about 10k miles on it. I do regular fuel induction cleanings 2-3 times a year. But nothing else has been changed. I am leaning towards the MAF sensor because I know it is a common problem with Fords but it has never giving me a problem with starting OR stalling. I am wanting to fix this problem first then plan on changing fuel filter, plugs, wires, MAF,maybe the coil, so I am willing to knock this out one at a time to find out but would like to narrow it down. If you guys have any suggestions please point me that way, I have access to a Snap On Verus so diagnostics should not be a problem.
Thanks guys!!!
Thanks guys!!!
