r6jon
- June 8, 2004
- New Jersey
- 97 XLT
1997 Ford Explorer Limited, 6cyl, 130k miles, Auto/4x4H/4x4L functions properly on Control Trac system. Light duty useage throughout lifetime/ female driver.
Recently there has been a terrible clunking, groaning and poping noise coming from the transfer case and front diff when turning slightly.
I know very well all about binding that occurs when using 4x4 on dry pavement - this is NOT the same thing. I'm talking about terrible clunking noises that shudder the whole car even with only 1/4 turn on the wheel with 4x4 engaged. You can even hear groaning when going straight with 4x4 engaged - but turning the wheels and loading up the driveline makes it really vicious.
keep in mind that I am the origonal owner of this car and I am not describing any of the typical noises associated with the 4x4 system. I'm talking about noises that would make any man cringe and beg for mercy!
Anyway, my cousin is a ford tech and he is almost convinced that the clutch pack in the transfer case is shot. He also thinks that the Amsoil ATF I put in the transfer case may have caused the clutch pack to fall apart and cause this banging when slipping/engaged.
One thing he did that supports this theory is powerbrake with the 4x4 engaged. Basically gas and brake HARD at the same time so the car can't move but the driveline is fully loaded. The banging noise started up even though the car wasn't moving! This suggests that the clutch packs may be slipping and fubar'ed.
I'm trying to make the right decision before I pay or commit to droping and dis-assembling the transfer case. I've been searching this forum for hours for the same symptoms and I can't find a conclusive thread as to what it may be.
I would greatly appreciate any help I can get! Thanks in advance. I'm sure this isn't the only 4x4 Explorer with high miles that has had this problem...
