Basic cheap mods to a 96 xlt | Ford Explorer Forums
pipdango
Portland, OR
'96 XLT
I have a bone stock '96 XLT and would appriciate some addvice on what some good basic cheap mods would be. Thanks.
P.S. It has the 4.0 V6
The main question is what direction are you going to go with it...offroad or street? If you want to lift it you can do a torsion twist and add a leaf (or warroir shackles WAR153). If you want to lower it you can to a torsion twist (just the other way) and lift blocks which actually lower our truck because of the spring under axle set up in the rear. DO a search and you will find all the info you will ever need :). You could also use a gutter gaurd material and make some grill inserts, it's been done before and looks pretty darn good :). Those are going to all the suggestions I have haha.
good luck
cp
As CP said, there's ALL SORTS of things you can do cheaply depending on your preference (street or off-road). Use the Search feature or simply read thru the Forums.
Good Luck - D.
If you're looking for performance mods, start with Swiss-cheesing your airbox. It's free! :D
