Banjoes
- May 25, 2012
- Florida
- 1995 Ford Explorer XLT
I am planning to replace exhaust manifold gaskets as the passenger side is leaking. I know it is leaking due to a recent seafoam treatment, and it never leaked out anywhere else. I am planning also to do a MAF sensor w/air cleaner change and other electrical sensor cleaning like idle air controller and throttle position sensor and air temperature sensor cleaning. Along with their respective electrical connections too. But before I do any of that I want to clean the entire engine compartment with a degreaser. I know some of the preparations before spraying the degreaser like covering the battery and ignition coil pack with plastic bags and securing them with rubber bands.
But Is there any other areas to cover up beside these items?
About the manifolds, they have been removed before when my dad and uncle put another transmission on the truck, they replaced the driver side and not the passenger side, I'm not sure why. Are there preparations before attempting removal and what is the easiest way to get at it?
Also what products do you guys recommend for cleaning the engine?
And also what CRC product should I use to clean the MAF, the other sensors mentioned above and their respective electrical connections? Should I use the QD electronic cleaner or their lectramotive electric parts cleaner, I want to buy ONE can if possible.
thanks in advanced,
Joe
thanks in advanced,
Joe
