Calgary351GT
- October 28, 2011
- Calgary, Alberta
- 2007 Explorer
Since having heat issues in my 07' Explorer, I have come to realize the whole blend door/ actuator thing is a real problem with Explorers. I have found plenty of info to diagnose such issues but mine seems to be unique.
First, we got the infamous 'clicking' sound from the blend actuator. Fine. Took it to a mechanic. He says the blend door is broke but I wanted to check for myself before dropping 1500.
The actuator is definitely slipping as I can see it trying to turn the blend door. My mechanics full of it, right? But wait. I pull the actuator off and check the blend door axle. It appears to be intact. My a mechanic is full of it, right? But wait again. I turn the blend door manually. It turns about 1/4 turn, freely each direction (which I have been told by Heatertreater is normal) and I can hear the blend door redirecting air. The problem is I still get no heat. Even with the fan on high.
Has anybody heard of this? What could it be? Can the blend door still be broken even if the axle is intact and appears to swing freely?
