Zhu
- December 22, 2007
- melbourne, Victoria
- 96 xlt
My 1996 XLT has the symptoms of a defected blend door. Except the Maxac has cool air, all the other options blow out warm air. It is summer here down under and you can imagine how alloying it is to sit in the car with the warm air blowing on a scorching day.
I searched the forum and found many creative and cheap ways to fix the problem. I decided to DIY and follow the instructions on this webpage http://www.blenddoorfix.netfirms.com/
My problem now is that I couldn't remove the actuator/motor from the clips it's attached to. It's said to "pry up gently" to remove the acuator. I tried gently and then hard, but neither way worked. I couldn't detach the actuator from the front two clips. I would appreciate it if you could give me some tips on how to remove the actuator from the clips. Please be a little bit specific in your description as English is not my native language.
I'd like to use this opportunity to thank the people who share their opinions, experiences, and expertise here. This site is great. Even though I am relatively a very new member, I have benefited a lot already.
