Blinking CEL, chugging | Ford Explorer Forums
exploration1997
Manchester, NH
1997 Ford Explorer XLT
Okay, so earlier today I noticed that the truck shuddered when accelerating from a stop. Today, on my way home from school, the Check engine light started blinking, so I pulled over and **** it off to look in the manual. That was no help. I had my mom come drive to where I was, and followed her home, and it literally was shuddering non stop on the way home. I've heard it could be a cylinder misfire, but what else could it be?
*************EDIT***********************
I have the 5.0 V8, AWD, 4R70W if that matters
Flashing CEL usually means a misfire. You need to read the codes to know what is going on.
Code scanners can be had cheap (< $50 at Harbor Freight tools)) or you can get fancy ones @ $120 up to $1000s
If you can drive it safely to your local chain auto parts store they will usually rent you a code reader (leave them your license as you use it). They used to scan it for you but now you do it yourself.
Anyway, your going to probably find a 3xx code (misfire code) which will tell you which cylinder is having the issue but not what is causing it.
I'd first check for a loose or burnt spark plug wire (lying against the exhaust maybe?). You can do that even before you check your codes/pending codes.
If you have any other codes they might be the reason of the misfire but you need to read them to know where to look.
~Mark
~Mark
Well the solid check engine light has been on for almost 8 months now. I pulled two codes before, and it was only because of my exhaust leak (a separate issue.....?). That was a borrowed scanner, my uncle is coming over later tonight to get the codes.
