blower motor and drivers door stopped working | Ford Explorer Forums
robbennett
Ohio
95 xlt
Hi my blower motor quit working two days ago so til I had a chance to look at it Ive just had my windows down. pulled the blower motor hooked it up straight to the battery it works checked the power relay box all fuses good here totally lost now please help. Back doors will open from outside but never inside both doors either position of child safety swich same thing. took the panel off can see nothing wrong took off the inside handle it moves but cant tell if it moves properly because both are the same.
************Fixed drivers window from forum tapped on moter inside door came right up***********************
Blower motor: check relay under air box. Rear door handles: remove one and check to see if the tab moves with the handle if it doesn't the gear is broken (common problem).
just found the issue with the door handles.
Where is the relay under the air box at I will check it
thanks
Rob
window problem is either broken T/LB or W/BK wires... check for voltages and grounds at the motor and trace from there... usually a door post wiring issue.
