Blower motor resister pack | Ford Explorer Forums
Dief
1999 Explorere Limited
Here's an easy one: Where is the blower moter resister pack for the front blower located on a 1999 Limited? I've lost the lower fan speeds and suspect that's the first place I should look. Thanks!!
on the heater box under the blower motor. 2 7mm screws hold it in. while your there, you should also pull the blower motor out and see if there is any leaves and stuff like that, and clean it out.
