blower motor switch replace | Ford Explorer Forums
cogs
texas
'94 sport 2wd
i'm replacing my broken blower motor switch, but i don't know how to get to it. how and what do i remove? the radio is already loose where i can get behind it.
Take out the ashtray and remove screws, start peeling the dashboard bezel up from the bottom, across the steering wheel, disconnecting switch wires as you go. From there, I suspect you will be able to unscrew the heater control panel, and get to the switch.
My ashtray was already removed for air shock guages/controls so all I had to do was yank that out of the way and work from underneath.
As far as I remember at least.. Didn't need to mess with the headunit at all
Benjam :D
