HenryTS77
- March 3, 2011
- Syracuse,NY
- 99 Explorer Limited 5.0
Hello all - I have been lurking here for a while soaking up the great info but now need some help I know there are a number of threads on this subject but they all refer to a blower motor with a resistor pack. However my Explorer as automatic climate control which I understand does not use the resistor pack. So here is my situation- I purchased my explorer about a year ago and the climate control system worked fine until about 4 months ago when it would only work on high. Then it stopped altogether- I did some research and checked connections , fuses and relays-all seemed good so I tried the tapping the motor with a rubber mallet and it worked at first. However over time the motor would start up but slowly and speed up as it warmed up but now it will not start at all. I can hear the the inside relay click as I move the speed control and the 40 amp fuse under the hood is good . All indications seem to point to the motor but just wanted to make sure considering my vehicle has the automatic climate control and if so is there a video showing details to replace this type of motor. Any info would be greatly appreciated.
