rojocru
- November 21, 2011
- 2003 Ford Explorer
Hello. My vehicle started making noisy sounds when I arrived home last week Friday. I didn't hear it again until this past Saturday (two days ago). I took it in to one place, but the guy at the mechanic place was not able to look at it. He said that he thinks it should be a chain in the motor. It may be the front or the back.
So, I took it to another place, and they checked the oil and saw that it was dry. They added some and checked the level, but it still was dry. They added some more and got a reading. The noise still persisted. They told that the engine was blown. They asked me before if the Check Engine light was on, and I told them no, which they were also able to verify after putting in oil.
As things are right now, the vehicle starts and drives, but it makes a lot of noise. Today when I slowed down on the road to make a U-turn, the vehicle turned off --the steering wheel was locked and lights were on. I turned the key in the ignition backwards to me to turn the vehicle off (though it was off already, except for the lights --you know what I mean). I then turned the vehicle on and continued with my journey worrying that it will turn off again.
So, what's happening and what will happen if I continue to drive the vehicle?
Will it stop suddenly / quickly while I am driving at let's say speeds of 30 to 50 something miles per hour or will it lose power / turn itself off gradually so that I can at least pull aside?
Will other parts of the vehicle --alternator, transmission, etc. become damaged?
etc.
I currently cannot afford a new engine right now. In about 3 to 6 weeks time I think I should have enough for the engine and labor, assuming that labor will be $1,000.
etc.
