Both Auxiliary power points not working | Ford Explorer Forums
Laurie1126
2004 Mountaineer
Hello to everyone out there I just got a hand me down 2004 Mountaineer and both of the Auxiliary power points are out. I have checked the fuse under the driver's side consul and it appears to be fine. Where should I check next??
My cousin you gave me the car said they just quit working not to long ago..
Please help I'm in a new city and need to be able to use my Garmin or nav on my android and I have to have power for those to work.
Welcome aboard!! :salute:
The fuse information is contained in the owner's manual. If you don't have an owner's manual, Dead Link Removed.
There are 2 fuses related to the power points in the battery junction box, located under the hood behind the battery:
Dead Link Removed
Fuse #7 is a 20A Maxi Cartridge Fuse labeled Power Point #2, Fuse #9 is a 20A Maxi Cartridge Fuse labeled Power Point #1:
Dead Link Removed
Check those 2 fuses and make sure nothing is stuck in the power points causing it to short out.
Hope this helps out. :biggthump
Please keep us posted as feedback helps others reading this post looking for a fix to the same or similar issue!
