I had a similar problem but mine turned out to be a short in the headlight switch, the headlights worked fine but no other lights. Probably not common, but something to take a look at if all else fails.
Common component in both those systems is the multifunction switch. It's the turn signal stalk on the steering column. If your fuses and such check out, look at it next. I've had a couple of these go bad recently.
