Brake Light | Ford Explorer Forums
Brake Light
organman
Whiteville NC
Ranger 92
Hello,
I have a 92 Ranger, replaced brake master cylinder, I now have plenty of pedal, but my brake light and antilock light is on. What has happened?
Thanks
normally, you can get code from the ABS system. I would bleed the air out of the system, starting fromt he farthest wheel first and working toward the closest wheel to the master cylinder. To clear the code, you'll have to unplug your battery while working on the bleeding and once everything is cleared out the trouble code should go away.
Thanks for your reply, I'll do those things.
