Scoobmaster
- June 20, 2006
- Endicott, NY
- 2003 XLS
Greetings Explorer owners/gurus:
I am a long-time Dodge/Chrysler car and minivan owner (ducks under thrown rotten veggies) that has come to the Ford side with a 2003 Explorer XLS. I just replaced my front brake pads and rotors on the Explorer yesterday and was somewhat mystified by the way everything was put together. I am used to a caliper that only has two slide bolts holding it and the pads on. It took me a few minutes to figure out that the Explorer caliper comes off with the two smaller bolts in the slide pins, and then you take the "cage" that holds the pads around the rotor off separately with two larger bolts. The little stainless clips ("slippers" is what I have now heard them referred to) puzzled me. they had a "death grip" on my old pads and I had to really pry on them to remove them. My new pads (cheap Autozone ones) didn't come with new slippers, so I tried to clean the old ones as best I could. However, even after cleaning, I felt that the pads with the slipper were held "too tight" and would not "float" or glide easy enough to release and not bind and rub on the rotor when the brakes are released. So I lubed the pad slide area and assembled everything without using the slippers. The caliper glides nice and free on the glide pins and the pads move very easy (obviously).
Now the question for the gurus here.... is this a big mistake? Is it OK to run without the slippers? Are they absolutely necessary for proper brake operation, or more for noise/rattle control? Should I buy new slippers in a "kit" and install them? ALL the Dodge cars I have ever done brakes on have had some "slop" where the pads glide in the top & bottom grooves of the caliper and have no "slippers" placing pressure on them (that is why this system of slippers on my Explorer seemed "foreign" to me).
Any opinions / help is appreciated.
Thanks for letting a "chrysler guy" into the Explorer fraternity
