PFC ceramics from Autozone. There is no substitution for ceramic and I paid around $45 per axle. They stop faster, respond quicker, fade less, dust less, and won't scout your rotors like semi-metallics can. Replace the rotors too. Don't machine them, replace them. That way the pad and rotor can bed together and should last you a long time. Get standard Autozone Duralast rotors. Cross-drilled and slotted are a waste of money. The braking power is in the pads and the fluid condition. Make sure the fluid is bled too. Brakes do not need to be expensive.
