Broken 3rd row seat power motor assembly | Ford Explorer Forums
Gilles Brassard
Alma, QC
2012, Explorer, Limited
I am looking for a replacement left 3rd row seat power motor assembly.
I have removed the broken unit. There is no part number on the unit. Google search did not help. I suspect the motor assembly only comes with complete third row seat module.
Can anyone point me to the diagram for powered third row seat or provide a part number or source to get replacement part.
Thanks in advance
Welcome to the Forum Gilles.:wave:
I haven't been able to find anything related to a 3rd row seat motor. I did find a control module; Control Module - Ford (AU5Z-14F042-B) | Auto Nation Ford White Bear Lake
I even looked under "motors" and did not find anything for the 3rd row.
As for a source, the dealership's parts department is a good place to get an OEM part. They mau even provide the actual part number.
Thanks in advance
How did you resolve this issue? I have a 2017 explorer platinum with the right side seat stuck in Fold position. It’s super annoying. Went to fix and the dealer wanted $1600! I need it fixed but can’t find any info about this part. The dealer said it was a known issue and they had seen it before, but he said you have to replace the bottom part of the seat and the motor. The part is almost $1000. Help!
For that kind of money and considering the young age of the donors, I'd hit up a junkyard. I'd also take your original out and look for the fault mode, maybe some kind of DIY fix or more lube on the replacement, fabricate a better part for what broke, or something.
Thanks. That’s what I’m hoping to do, but haven’t had luck finding the seat frame at a junk yard. I’m going to try to take it out, but there’s no error code so far.
Welcome to the Forum. :wave:
The member you quoted was last seen here on May 28, 2018 so I doubt you will get a reply from him.
I want to say I found a part number for the motors a while back after some mental gymnastics, but I haven't torn into our ex to see for sure what's wrong to look again. I can tell you the MKT and Flex should use the same part when equipped with a power third row, which may aid your junkyard search at least.
Another option might be convert to manual operation? I'd seriously consider that, since it has already failed once and I wouldn't want to have to fix it again, and again.
