chips2481
- July 1, 2007
- Minnetonka Minnesota
- 1990 Ranger XLT
Hi I had bought a 90 ranger with 2wd. I had thought the problem with the noise was the bad center drive shaft bearing since it was so bad that the axle would shake when it drove. I replaced that and it stoped the driveshaft from shaking but didn't fix the noise
I am new to rear wheel drive vehicles. Anyways it looks like the last idiot who drove this thing didn't take care of it and now I bought a 1500 truck with a bad differential and bad motor mounts...I am assuming that the bad drive shaft bearing's shaking had ruined both the diff and motor mounts. Also when I am going over 55 the engine ticks because it can't handle all of the power the engine needs to produce at such a low rpm... so I think one of the valves is bent as well, maybe it got bent from the engine shaking from the bad mounts. Any ways I am past the fact that I got jiped out of cash and just want to repair this thing. First I looked for a replacement diff and couldn't find a used one. I have spent a few minutes looking for a new one at autozone.com and found nothing. So now I am trying to figure out how to repair it. I see the site below has some parts to repair it but no new entire diff replacement.
http://www.autozone.com/N,11201707//shopping/partTypeResultSet.htm
Will any of these parts fix it? I have taken the drive shaft off and the diff has back lash, which is what my dad told me I have knowledge of differentials but it is loose and will move alot when you turn the drive shaft. How would I go about fixing the diff completly?
