MrDugan
- January 23, 2022
- Crittenden
- 98 mountaineer 5.0 awd
I am curious if i can delete the heater control valve temporarily to get some kind of heat in my truck until i have time and its warm enough to do a full run down. My temp gauge drops when reving but air gets a small bit warmer. No leaks anywhere and it dont over heat at all. Have "burped" the system 6 times and still have no heat. Radiator and tank are full. I am lost on how to fix it properly and just need a bandald for now. I have replaced heater control valve, thermostat twice, burped 6 times, no weap from water pump, check vac lines, replaced climate control knobs, and no leak in truck. I am lost. Can i just runs the lines straight to heater core lines without damage being caused or does anyone know wtf is wrong with my heat?
