Cannister purge selenoid broken off! Can I plug the vacuum line? | Ford Explorer Forums
mawrazen
Atlanta, Ga
94 Eddie Bauer
Or will I explode???
I fabricated a coupling but its leaking. The plastic is broken off in the lines and I cant seem to get the plastic out. Its almost as if ther seleonoid was attached to ther line???
Where does the vacuum line lead to under the throttle body?? I cant see where it goes and my Haynes manual is not much help.
Thanks, :)
It goes right into the bottom of the tb.mine has been stuck shut for awile.all it has affected is the idle a little and it hisses like crazy when I pull the gas cap off to fill up.they are pretty cheap at rockauto or junk yard.
